ford 600 weight question
/ ford 600 weight question #1
mycaddigo
Buffalo, NY
ford 600
have a ford 600, it has wheel weights, calcium in the wheels, and a bucket on it.
I'm in the market for a trailer and I'm not really sure how much it weighs. And going from 7000lb gross to 10000. Not sure if I'll get away with the 7000 gross if the tractor weighs over 5000lbs.
Im a total noob, so any help would be apreciated.
Thanks for your repy, yeah it said it weighs between 3031 to 3641 pounds,
That 600 lb differece i have no idea if it includes wheel weights ect.
/ ford 600 weight question #4
The 66 inch FEL on my tractor is about 1100 lbs and the beat juice in my large rear R4 tires is about 1200 lbs. If you have Ags for rears I would estimate about 700 lbs for them and your FEL is probably a tad lighter or about the same as mine. I would say that these items would add 1500 - 2000 lbs to your tractor and say you should plan for a total weight of about 5000 - 5500 lbs with fuel and other fluids in the tractor.
no the news i was looking for, but thank you so much!
/ ford 600 weight question #6
I have a comparable tractor with a FEL and fluid in the rears. It weighs 5,200# with nothing on the 3 point.
Chris
/ ford 600 weight question #7
i have towed 00 series fords with laoded tires and a loader on a 7k trailer for years.. many years.. many, many years.
and yeah.. I'm sure i'm right at the hairy edge ..
my 16' trailer is 1740
leaving 5260 payload on the axles..
means the spare has to ride inthe truck ;)
40ft Six Section Heavy Duty Metal Storage Shelf (A64047)
40ft Six Section...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A61573)
2017 Autocar...
1999 GMC C7500 Truck, VIN # 1GDL7H1C8XJ515294 (A61573)
1999 GMC C7500...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
