Ford 600/800 series 5 speed transmission
   / Ford 600/800 series 5 speed transmission #1
farmallbill
Northern Pa
farmall m, Allis Chalmers WD x2, Husky 390XP, Husky 455 Rancher
Why would the 5 speed transmission come out of 5th gear when going downhill or when there is no load against the transmission on the Ford 600/800 series tractors? Any help is appreciated.
Thanks
farmallbill
   / Ford 600/800 series 5 speed transmission #2
Thought I posted a reply to this but it's gone now. So excuse me if this is a duplicate.
I've saw this several times over the years. The gears are cut to hold themselves engaged. Too many times of grinding it into gear causes the teeth to round off. Then there's nothing holding it engaged. Just guessing though.....
There are some expert Ford tractor guys on here. Hopefully we'll hear a definite answer. :)
Thanks sounds like a good guess. Yes you did reply on my other post. Forgot there was a vintage Ford forum, found after first post
   / Ford 600/800 series 5 speed transmission #4
Oh, sorry, I didn't even notice that.....
Hopefully a couple of the Ford Gurus will chime in. Soundguy or RickyB are both very knowledgeable.
   / Ford 600/800 series 5 speed transmission #5
As mentioned, most likely bearing and gear wear. Won't hurt to check detent plungers, just because it is easy.
If trans n gears, fix is full trans rebuild, or new used trans.
Bandaid fix is a bunji cord holding the shifter in gear, but not so hard its passing detents.
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2021 Harley-Davidson FLHP Police Electra Glide Motorcycle (A51694)
2021...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
1274 (A50490)
1274 (A50490)
THE HANDLER II MIXER UNIT (A53843)
THE HANDLER II...
2013 Ford Fusion Sedan (A51694)
2013 Ford Fusion...
