Ford 555
   / Ford 555 #1
Yellow dragon
Ford 555 backhoe
I’m left with a Ford 555 digger (1975-1984). I don’t know where the transmission fluid opening is to add fluid. Please help.
   / Ford 555 #2
If it has the torque converter (No Clutch) shuttle shift the transmission fill is just to the left of the gear shift lever under the floor
It should have a dip stick with markings attached to the threaded cap
ps. a 555 started production in late 1978 IIANM the 550 was built between 75-78 but the service manual covers both models , so very similar units.
   / Ford 555 #3
While you're at it, just behind the transmission fill/check is the rear axle fill/check under an identical 2 bolt cover (if still there).
Golf Cart (A48082)
Golf Cart (A48082)
2011 Ford Explorer Limited SUV (A46684)
2011 Ford Explorer...
Free Standing Panels (A49339)
Free Standing...
45024 (A48082)
45024 (A48082)
Galvanized Pipe (A49251)
Galvanized Pipe...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A45678)
2019 PETERBILT 579...
