Ford 555 axle - interchangeable with 545A ?
   / Ford 555 axle - interchangeable with 545A ? #1
coppolajc10
Dunkirk
ford
Hi, came across a 545a axle (see picture attached). I have a Ford 555. Axle on mine have egged hole where pin goes through axle and bushings for pin on spindle are wore through into spindle itself. Does anyone know if this axle off 545a would fit on my 555. Thanks.
   / Ford 555 axle - interchangeable with 545A ? #2
I looked at the parts diagrams for both models at Messicks New Holland parts. The spindle bracket appears to be different between those two models. The 545a list the following models for its axle: (03A02) - FRONT AXLE, STEERING, 445, 445A, 450, 545, 545A (78/); 340, 340A, 340B, 540, 540A, 540B (4-81/) Hope this helps
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2007 GMC 2500HD (A56436)
2007 GMC 2500HD...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
