Ford 5500 backhoe pump noise
   / Ford 5500 backhoe pump noise #1
Jrus
Argentine, MI
Ford 5500
Iv got a ford 5500 I recently acquired from an old lady. It was her dads and it was parked when he got to old to run it with only 500 hours on it. Long story short It worked great. Untill now. This winter my suction line collapsed at the tank where the rubber elbow comes out of the tank. It was about -15 out so the hyd oil was extream oh thick. Anyways this elbow is no longer avilable so I wielded two barbed ends together in a 90 and coupled with 2" hyd suction hose to replace the elbow this spring when it warmed up. Now iv got a loud howeling noise when trying to run anything hydrolic. I know there's air in the system but I cannot figure out how to blead it or reprise the pump. Everything works just very slow and lots of pump noise. Don't want to burn the pump up. Please help!
   / Ford 5500 backhoe pump noise #2
You probably have a suction leak.
Iv got every coupler on the suction line replaced. Only thing I didn't change was the pump seal. But it is in pretty good shape. Iv just got air in the pump system and don't know how to bleed it out???
   / Ford 5500 backhoe pump noise #4
You may have run the pump with ice blocking flow out of the tank.
Old iron collects water ... even in the oils.
If the oil tank is full, your pump will self prime. If the lines are clear and the pump in good order. Can the hose have collapsed and delaminated? It would look good externally, but wouldn't flow.
Good luck
   / Ford 5500 backhoe pump noise #5
A hyd system self bleeds by using the cyl or motors.
Some people use a heavy grease on all the fittings and hose to see if the leak stops.
Yo probably can not see a pin hole leak in a suction hose.
I'm going to drain all oil and flush the system and clean out the tanks. Some dealer told me I should use a 20 weight hyd oil. I thought at least a 32?
   / Ford 5500 backhoe pump noise #7
Can you explain how the pump primes using a cylinder or motor? Thank you.
   / Ford 5500 backhoe pump noise #8
Most gear pumps will prime if the in port is flooded.
The cyl or motor need not to be in the circuit.
An open center hyd system is always pumping fluid.
If the sump is lower that the pump. air may be necessary to help force fluid though the piping, about 5
psi.
   / Ford 5500 backhoe pump noise #9
This is what Jrus said.
[ I cannot figure out how to blead it or reprise the pump ]
In order to bleed, you have to exercise the hyd components.
To prime, you have to have fluid at the pumps IN port. This happens quickly when the tank is above the pump. If tank is below the pump, it may take a while.
Your welcome.
Tank is below the pump. Iv got 20 gallons to put in it tonight ill probably have to get some more before I fire it up. Hopefully once it's full it will get fluid and I can get the air worked out.
378538 (A51573)
378538 (A51573)
1269 (A50490)
1269 (A50490)
2019 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2019 FREIGHTLINER...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A53472)
Adams Load Out...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
