Ford 550
/ Ford 550 #21
I'm taking a trip on Sunday to look at a 550. I've been stalking this thread and have read it a few times.
Any additional thoughts on this machine?
/ Ford 550 #22
Well, I visited the machine. It had a few quirks as you would expect from a 35 year old machine. It had some perforation on the side of the bucket, a bit of minor rust on the hoe hydraulics, a minor bend in on of the steering pistons although it seemed to turn just fine. The starter was quirky and about half the time it took a few turns of the key to turn over the engine, but when it did, it started right up and ran clean.
The only bits that really concerned me was the hoe chain was very loose on the opposite side when the hoe was pivoted 90 degrees, and there was oil around the filter under the chassis. Is this the dreaded transmission leak?
/ Ford 550 #23
Leaks between the two cases. Mine has been blowing hydrolic hoses. Now I think my engine need to be rebuilt. Wont start umless I use starter fluid or the glow plug. I replaced the injectors. I am guessing its a compression issue. I had to rent a mini excavator and since then had a hard time going back to this older machine.
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
BOBCAT T190 (A60736)
iDrive TDS-2010H...
2021 CATERPILLAR CB1.8 DOUBLE DRUM ROLLER (A62129)
2021 CATERPILLAR...
