Ford 550
/ Ford 550 #21
I'm taking a trip on Sunday to look at a 550. I've been stalking this thread and have read it a few times.
Any additional thoughts on this machine?
/ Ford 550 #22
Well, I visited the machine. It had a few quirks as you would expect from a 35 year old machine. It had some perforation on the side of the bucket, a bit of minor rust on the hoe hydraulics, a minor bend in on of the steering pistons although it seemed to turn just fine. The starter was quirky and about half the time it took a few turns of the key to turn over the engine, but when it did, it started right up and ran clean.
The only bits that really concerned me was the hoe chain was very loose on the opposite side when the hoe was pivoted 90 degrees, and there was oil around the filter under the chassis. Is this the dreaded transmission leak?
/ Ford 550 #23
Leaks between the two cases. Mine has been blowing hydrolic hoses. Now I think my engine need to be rebuilt. Wont start umless I use starter fluid or the glow plug. I replaced the injectors. I am guessing its a compression issue. I had to rent a mini excavator and since then had a hard time going back to this older machine.
1012 (A61165)
1012 (A61165)
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2017 John Deere 8245R (A60462)
2017 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
96in Skid Steer Fork (A59317)
96in Skid Steer...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
