Ford 550
/ Ford 550 #1
thahn1608
I'm considering buying an older Ford 550 backhoe. It has 4 levers for the hoe, so it must be from the early 80's or older. My question is this.
Is it a reliable machine to dig foundations and footers. I mean it is big enough to handle large rocks and such. I have driven some big machines that just doesn't have the power to dig out small boulders. On the other hand I have been very impressed with some smaller machines. Does the 550 have the weight and power to match others in its class? I don't want to spend the money on something that won't be big enough for what I want it for. I'm located in South Eastern PA so the soil is part clay, and very rocky.
Anyone with experience on one of these machines is welcome to respond. Any videos or pics of one digging would be fantastic. Youtube doesn't have anything that I can find. Thanks!
/ Ford 550 #2
I work in rock country. The 550, in it's day was a beast. Built between '75 and '78. The BH was a beefed up version of the 4500. The engine/trans/rear axle is nearly identical to the 3500/4500. The flat deck, loader, front axle, and frame were all new and used until the 555C came out in the late '80's.
In good working order, the BH should be able lift, as I recall, over 4000 lbs. Keep in mind the age of the machine. It was known as one of the best, and fastest trenching machines.
As far as pushing power, by today's standards, it is weak. I think the engine was rated at 50-55 HP. NH's smallest BH for the past 15 years is bigger than 75HP, and topping out at 110 HP.
/ Ford 550
What would be the weight of this machine? Would a 5 ton trailer haul it?
/ Ford 550 #5
others be able to say better, but when i went and looked at i want to say 14 specific TLB (tractor loader backhoes) i found off of tractorhouse.com and sister site machinetrader.com and some local papers. i did this all in one day looking at them 20 plus hour day needless to say.
a 3 cylinder diesel vs a 4 cylinder diesel. was a huge difference in power. regardless of manufacture make or model. i mean ya get into them and took them for a test spin up into some dirt piles or like. and just night and day difference in power differences and reaction speeds.
the 555c TLB ended up getting and now have, ((was actually the very last one on the list i was going to look at))
i think is rated for 4200lbs in FEL and 2100LBS for the 12 foot BH.
it is a digging machine for sure.
as far as actually finding a TLB, for what you are wanting, i would be looking for a construction TLB. meaning a single seat that ya pull a lever to switch between driving tractor and backhoe use.
as far as finding out if tractor is worth getting or not. after that day of test driving them all. i would suggest shut your eyes as far as how they look (rust, paint, etc...) ugly looking tractors on interent ran good while others look new barely ran. it was a mix of it all.
some had a lot of slope in the BH (backhoe). when i say slope, ya swing the BH left and/or right. and sudden stop and they would keep on going. or if ya raised BH all the way and sudden drop and sudden stop of levers. and the BH would just bounce all around.
same went with the loaders on them. but the BH are more imporant less slop the better.
as far as transmission, engine, rear end, and hydraulics. get in them, start them up let them idle for about 5 to 10 minutes to let them warm up, do a test drive of them.
run loader into the ground and see how much power there is to keep on pushing into ground to see about digging. run at all gear speeds, then do same thing with full bucket of dirt and see how the power is in all gear speeds. run the backhoe, no need to dig, just work everything 10 to 20 times. to get hot warm oil in all the cylinders and lines.
once ya done with the inital test drive, set the throttle half way to 3/4 and let it set for 30 minutes to an hour like that. then redo all your tests. and see if there is a difference. on a couple of the TLB i tested i remember a decrease in power.
when you are all done with tests, raise the FEL (front end loader) up all the way, and do same thing with backhoe and the Turn OFF the tractor. and wait for 30 minutes and see how far they come down. the more they drop the more likely valves, seals, etc... are worn out.
the 555c just the main largest cylinder for BH has a small leak. and over 24 to 48hour period will drop down to ground. but over the initial 30 minutes you can hear it slowly drop, as it grinds and moves within the joints of it. the lock pin to lock the BH up when driving some were down line before i got it. look like it got hung up on something and tore the pin out. and was never fixed. so i am guessing all the bouncing around. caused extra strain on seals and valves. which is result of this. but beyond that. it all works.
if ya serious about TLB, be willing to drive 3 hours away. and test drive a few older ones. so you get a better idea of things.
once ya get one, get a shop manual, the 555c TLB shop manual i have is about 5 to 7 inches thick and very detailed info in how to tear stuff apart, check things and then steps to put it all back together.
/ Ford 550 #6
Those Fords were a pretty tough rig, but I question digging foundations with a backhoe. A small excavator will cost more but dig 5x faster. You wouldn't have a truck loader, but we don't know what your work is. I ran a 4-lever hoe for several years way back and you do get good at it but two is a smoother setup. Good luck, whichever way you go.
Jim
/ Ford 550
I greatly appreciate everyone's response! I love forums where guys know it all and are willing to share.
I don't have a huge amount of cash on hand and it has a rebuilt motor that he claims is worth 4k. It isn't hardly rusted. I know that it will need a power steering hose, and a muffler (he never got around to putting the hoods or muffler back on after the motor swap). He's only asking 5k for it. I've looked into other options, but right now this is what I can afford and it might be slower, but if it will do the job then that's what I need. This should pay for itself in 2 jobs so in a few months I can look for some more equipment - skidsteer, excavator, etc.
I've been in the construction business for years, and have always hired excavators, or rented the equipment. I took a look at last year's numbers and decided that if I have my own equipment I could save about 20k a year. That said, I'm thinking of an all-in-one machine first then branching out into some more "specialized" equipment. As always I appreciate your input!
/ Ford 550 #8
I know it has been a little while since your last post, but what do you think about the 550 now? I have been keeping an eye out for a backhoe for our 20 acres and ran across a 72 Ford 550 today.
Thanks,
Nick
/ Ford 550
I love my machine. The previous owner didn't own a grease gun apparently, so I have spent a good bit on repairs because of it.
The overall machine is great. The engine doesn't have the horsepower of more modern units, but it is almost indestructible. These machines were turned around and used as their heavy duty fork lifts too so the drivetrain parts are easy to find.
One thing to watch out for is the routine maintenance. If you test drive it push the bucket down far enough to lift the front wheels off the ground and climb underneath and check the king pin (the pin that holds the axle to the frame. Also look to see how the front frame is attached. The oil pan is actually what the front frame bolts to, so make sure the bolts are tight and they don't have a lot of spacers. If they have a lot of spacers then you are probably looking at a $2500 bill at the shop to get it fixed.
Also look for any transmission fluid leaking from the sight hole on the bottom. If the plate isn't off then unscrew it and check for any leaking oil. If there is - RUN!!! The transmission is bolted to the engine and there is a gasket in between. This gasket holds the transmission fluid in. The only way to change the gasket is to split the entire unit and remove the engine. It's about a 40 hour process at a professional shop. It's not something you can do yourself (besides needing to separate the halves each weighing 6,000 pounds) because it has to be aligned perfectly or you have to do it all over again when the gasket leaks... If the current owner doesn't let you check this, then think very carefully on how to proceed.
Overall I would say if you get the 550 for a good price then yes, it is a beast. It will work hard and ask for more. It might not be the most powerful, but it is very reliable. I would buy mine again if it didn't have the maintenance issues from the previous owner - it's cost me a lot of money and time - but not because it wasn't well built, just not well maintained. If you have any questions feel free to ask. I'll try to help for what it's worth.
/ Ford 550 #10
Awesome, thanks for all of the advice. This one had a good bit of slop in most of the pins on the backhoe. I kind of expected this for '72 model. It seemed to run pretty good and move pretty good.
I seen your post after I looked at it but I will check some of this if I go back. He wanted $7,500 for it. Seemed to high for that old of a machine and the work I knew it needed (not sure about what I did not know to look for).
I shot him a low offer and he may/may not call me back. But that just seemed high, maybe it is not.
I may be sending you some more questions if I end up with a similar machine.
Thanks again!
Nick
/ Ford 550
I have almost $12,000 invested in mine including purchase price. It is a brand new machine though - complete with rebuilt engine. I would sell it if the right offer came along, but I have no intentions of selling it. $7500 for a great working machine would be a deal, but if it has a lot of slop in the pins then you might be looking at something that hasn't been greased much. The side to side motion will be a little slow on the stopping because of the relief valve so don't worry about that - it's built that way. Be sure to check the hoe for welded cracks or patch repairs if is that sloppy. It might have stress cracks that aren't apparent at first blush. Check the cutting edge of the bucket as well. If it isn't straight then it will have to be replaced to get that level even cut for fine excavation - about $400 repair at the shop. The bucket will tell you details of how the machine was used. If it has a lot of dents from rocks then it has had a hard life probably digging and banging against bedrock. If it looks relatively smooth then it might have had an easier life. Feel free to ask any questions or concerns you have.
/ Ford 550 #12
I just bought a 550. I read all of the above post. My tractor does leak a lot of oil from the belly. Is there any possibility of helping slow down the leaking with some sore of transmission sealer? I can't afford 40 hours of shop time to puput in a new seal. It drains my transmission in about 3 or 4 hours of work. Any suggestons?
/ Ford 550 #13
Not much way around it, but to reseal. However, 40 hours is excessive. 20-25 hours more reasonable. What will cost you is once apart, the proper repair is to reseal the forward/reverse clutch packs, seals and sealing rings. What you may end up addressing is excessive wear on the clutch discs and/or other worn parts that should be replaced. The transmission pump where the seal is leaking may need to be replaced as well. The condition of the pump can be determined with a pressure test before it is split.
Just a few things to consider, but you could just split the tractor install the seal and go.
/ Ford 550 #14
I poured in some Barr's transmission stop leak and it seems to be helping. Didn't completely stop but it definately slowed down. Might that stuff cause things to get worse down the road?
/ Ford 550 #15
Hey Guys! I just picked up a 1978 550. typical leaks all over but not severe. I will address them one by one and get her right. Right now my biggest issue is I have no working block heater and its 15f outside.... If it snows I wanna use it but wont start. Do you guys recomend trying to replace the block heater or install a kat inline on the lower radiator hose. Reading reviews on this thing they are both positive and negative. I looked into the dipstick kind but they had 80% negative reviews. Where is a good website to go to for parts for this machine?
thanks
/ Ford 550 #16
The block heater is the way to go. New Holland still makes one for that and there are after market block heaters as well.
Messicks is a good sight and dealer as it has availability and price. Make sure put the model number in the Ag. section for the 550.
86578375 Block Heater from Messicks $85.59 in stock.
/ Ford 550 #17
Tractor Tech, I have been told that the correct heating element for the 550 is 86590140 not 86578375. I have a 1978 550.... which one is right.
Thahn,
Hows your machine doing today? any new issues to speak of? I actually have fluid coming from the sight whole plate but at this point have intention of ever splitting the case unless it really really bad. I mean I drove the machine home took me an hour. Parked it in the driveway and I have maybe a tablespoon of fliud on the ground from the sight plate.
/ Ford 550 #18
Chrisofman, 86590140 is a single element while 86578375 is a dual element. I didn't see that one right off. Either way, a heater for a Ford Basildon series engine (like yours) from 1975 to 1999 and a few later New Holland units with the same engine will work.
I did see the 86590140 on ebay for a Ford 2600-3600 with a current bid of $6.00 with 11 hours to go and $4.00 shipping. It will work as it is also 1.5".
/ Ford 550 #19
I just ordered on from Messick's oh well. I check ebay and did not find the one you were talking about.
2019 Kia Sorento AWD SUV (A61569)
2019 Kia Sorento...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
Chevrolet 2500 Flat bed (A61307)
Chevrolet 2500...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
207271 (A52708)
207271 (A52708)
