ford 545 backhoe
   / ford 545 backhoe #1
anninlahonda
la honda,ca
1981 ford 545 backhoe
I need help!!how does the starter work on this 1981 machine ?
   / ford 545 backhoe #2
could you perhaps post a bit mor einfo.. or actually state the problem you are having? so far we know you are having some issue with the starter.. is it not engaging with the key? or are you actually asking for an explanation of how the starter functions.. IE.. spinning and bendix/drive gear.. etc...??
   / ford 545 backhoe
I'm sorry .I need to find out how the fuel gets switched on and off is it electrically thereare two connections on the injector pump what do they do?Thankyou for your patience
   / ford 545 backhoe #4
if you see wires to a solenoid on the back of the IP they are almost deffinately a fuel stop solenoid for key/off operations.
follow your fuel line from tank to IP..
I'm not familiar with that machine.. but it should be clear what it goes thru.. IE.. electric fuel pump, mechanicl lift pump, and or sediment or water seperators and filter heads.
post back what you find.
   / ford 545 backhoe #5
ps... this new of a machine question is likely better handled by user RickB or Whodat. I'm an 'old' ford guy.. if it's late 70's it's kinda 'new' to me.. :)
if it was made while we were putting the man on the moon.. I'm on it.. :)
   / ford 545 backhoe
Thanks I'll let you know after I see my friend tonight.
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
1996 International Water Truck with a Caterpillar Engine (A53473)
1996 International...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A54607)
2004 TRAVIS 48'...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2025 K4525G UNUSED Double Garage Steel Barn (A53117)
2025 K4525G UNUSED...
