Ford 5000 Starting problem
   / Ford 5000 Starting problem #1
gcurell
Mayville, mi
ford 5000
My Ford 5000 Diesel has a bad battery. When I try to a charge the battery, the tractor tries to start on its own as soon as the battery has enough charge. This happens even with the key in the off position. Is this a switch problem or might it be something else? I need help!
   / Ford 5000 Starting problem #2
Re: Ford 5000
. . . I need help!
They say that is the first step! :D
Seriously, it sounds like the starter solenoid is stuck. Change that, and you should be OK.
   / Ford 5000 Starting problem #3
As Bigfoot says, or it could be the starter switch.
   / Ford 5000 Starting problem #4
yep.. solenoid contacts probably welded due to trying to start with a weak battery in the first place.
rap the solenoid with a hammer and see what a jump test does.
be safe.. trans in neutral, clutch blocked.. etc.
use an ohm meter too if needed to find what is shorted / closed.. etc..
always could be a bad key switch.. etc...
   / Ford 5000 Starting problem #5
A volt meter and a little patients will go along way.
And for starters, I'd unhook the battery and let it get a FULL charge.
Try tapping the solenoid on the starter as soundguy metioned. And then with a FULL charged and UNHOOKED battery, all you have to do is touch the cable back to the battery. If she tries to start, you know the tapping didnt work. And then a little ohm testing with a VOM is in order, as well as a little knowledge of what/where to check:thumbsup:
FORD COBRA REPLICA RACING CAR (A51222)
FORD COBRA REPLICA...
INGERSOLL RAND G25 GENERATOR (A50854)
INGERSOLL RAND G25...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2018 PJ 40T/A GOOSENECK TRAILER (A50854)
2018 PJ 40T/A...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2008 SHOP BUILT  STEEL TANKER TRAILER (A50854)
2008 SHOP BUILT...
