Ford 5000 hydraulic pressure loss when hot
   / Ford 5000 hydraulic pressure loss when hot #1
D Tackney
Ford 5000
Loader and linkage work fine when cold however after using PTO for 20 mins hydraulics stop working, any help would be much appreciated
   / Ford 5000 hydraulic pressure loss when hot #2
Maybe the pump is getting starved by the pickup filter or some rubber pieces are softening and getting air in the system?
   / Ford 5000 hydraulic pressure loss when hot #3
Did this problem just start all of a sudden?
   / Ford 5000 hydraulic pressure loss when hot #4
That very same thing happened to my 5000. When I got it the fluid was chocolate milk. Drained, flushed, refill with fresh fluid. Three time. Running brush hog after 3rd time and everything quit. Suction screen on pump was plugged solid with paint chips,sawdust, and what looked like the remains of one of those desiccant packs. I mean plugged solid. Apparently the previous owner wasn’t picky about the cleanliness of the bucket they were using. I had to split the tractor to get all the dirt out.
   / Ford 5000 hydraulic pressure loss when hot #5
I’m having issue now. I’m my 5000 for hay baling. Yesterday pto was engaging fine but after about couple hours of running it, it just stopped in mid bale. I haven’t checked strainer. I hope it’s not pump!
   / Ford 5000 hydraulic pressure loss when hot #6
By all means check the strainer and return filter while you’re in there. You need a gasket for the pump so the pump gear has correct clearance. Check the relief valve on the pump maybe stuck.
   / Ford 5000 hydraulic pressure loss when hot #7
Hyd. pumps usually work or they don't. Dirty filter is a common problem. If the Hyd. fluid is so low that it won't function usually means it has a leak involved to cause it. Most all the pumps have a pin on the Hyd. pumps Dr. shaft that will shear and totally quit. Helps prevent damage to the pump itself. Been through the extra Super Nasty Fluid and Filter Screen. I had to replace the screen it was so bad. Whale oil and pretty much what it looked and smelled like! Org. rice patty Yanmar!! Which has a relief valve on it also.
   / Ford 5000 hydraulic pressure loss when hot #8
When it happened to mine had to clean out the relief valve, partially stuck open and when it got hot and the fluid thinned out it was open just enough that it had almost no pressure. I think this is probably a 5000 thing and I’ve often wondered how many pumps just got replaced vs checking. Not saying the pumps not bad but worth $500 to me it’s easy to check. Fixed mine.
   / Ford 5000 hydraulic pressure loss when hot #9
If your 5000 is like the one we had their is an oil passage in the transmission housing that feeds the valve bank on the plate the seat bolts to. The O-ring that seals this failed on ours and caused loss of pressure. If my memory is correct their is an inspection plate below the brake pedals on side of trans housing that you can remove. Then have some operate the tractor while watching for oil flow with no load and then slowly start to dead head a function and watch for oil spray.
The passage in question was on right side as sitting on tractor.
   / Ford 5000 hydraulic pressure loss when hot #10
That’s a possibility too. My 5000 is a 1967 and there was a driveline brake on the left side. On a 1967 that’s where the plate you speak of would be.
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
John Deere 5400 Tractor with Loader (A51573)
John Deere 5400...
