Ford 4630 Power steering problems
   / Ford 4630 Power steering problems #1
hillbily
Corning, Arkansas
Ford 4630
ok guys I am a newbie to the site but not for working on tractors. I need some help.
I have a 1992 ford 4630 FWA with power steering problems. First it was leaking fluid bad so I bought a kit for new Holland and removed the pump. The kit comes with a couple of seals and a bunch of O-rings. I have a breakdown of the pump to go by when I disassembled the pump. I also cleaned each part and laid it out in order to make reassembly easier. I replaced all the seals and O-rings that were in the kit plus some that I got from ford that was not in the kit. I also replaced the filter in the pump with a kit from ford. I reinstalled the pump and now my power steering sucks. at an idle it is very hard to turn. If I bring the rpm's up some it turns a little easier but it still seems harder than it use to be. I am using the fluid the dealer told me to use so I know it is right plus it is the same as I was using before. If you are moving and the rpm's are up some it seems fine. the gears in the pump looked fine and the bearings had a little wear but it was working fine before the leak. I have even cracked a few of the lines to make sure it does not have air in the lines.
Hopefully I did not leave any thing out. Does anyone have any ideas?
Thanks for any help at all.
Update: Thanks to Harry in KY. I pulled the pump back apart and rechecked the floating bearing blocks and one was a little tight. Lite sanding with 1500 grit paper and it fit much better. The steering still seems a little stiff while it is sitting still at an idle but just a smidge of rpm's and it is fine. Thinking I might still have a little air lock but I think it is good. Going to run it a little and keep an eye on fluid level. If anything changes I will repost. But as of now It seems fixed.
   / Ford 4630 Power steering problems #3
I know some of the Ford compacts have "weak" PS at idle: maybe your 4600 series is similar. Anyway, glad you found a fix.
Jim
John Deere 1020 Tractor (RUNS) (A50774)
John Deere 1020...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
2018 CATERPILLAR 239D SKID STEER (A51242)
2018 CATERPILLAR...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
