ford 4500
/ ford 4500 #1
m4500
ford
need to add transmission oil to ford 4500 backhoe manual transmission wet brakes. what i am told is it needs m2c-134d oil i can't locate any will jd120c or j20c oil be the same? if not what would be the same as the m2c=134d oil
/ ford 4500 #2
Just pickup some universal tractor fluid, all I have seen many years has been 134D compliant. Come to think about it think J20 may also be listed on the label, guess I need to look.
/ ford 4500 #3
Some info I found on the net:
Ford M2C-134D (Multi-G) and John Deere J20C (Hygard) are basically equivalent specifications.
Travelers' brand UTF from TSC equivalent to 134D check the label on the bucket
You can use any UTF that says on the label that it meets the Ford 134D specification. Check the label
willy
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A61306)
2023 Takeuchi TL6R...
(14) WOOD PALLETS (A60432)
(14) WOOD PALLETS...
2021 NORAM 65E TURBO MOTORGRADER (A60429)
2021 NORAM 65E...
2013 REITNOUER 48FT FLATBED TRAILER (A59905)
2013 REITNOUER...
2014 JLG 6036 6,000lb 4x4 Rough Terrain Telehandler (A59228)
2014 JLG 6036...
2022 CATERPILLAR 330 EXCAVATOR (A60429)
2022 CATERPILLAR...
