Ford 4500
/ Ford 4500 #1
Swblack1216
Washington state
Kioti ck25, Ford 4500
ford 4500 ind industrial is it vintage ? If so I’m prehistoric! Just want to know which forum for discussion?
/ Ford 4500 #2
/ Ford 4500
I would consider it vintage and yours looks like it's been restored or well cared for. Data on it here: TractorData.com Ford 4500 industrial tractor information
Not restored I did 100 foot spray paint job the seats were shot. I replaced them with a Chevy Silverado 50 bucks and one of my boat seats will be upgraded to black tie, wraps, added muffler, the gauge Consol wiring harness new starter , owner installed new injector pump. I put a Thermostart in. Don’t think it’s working right. Dug up my first stump with backhoe. Everything works good. Three cylinder diesel 740 loader 755 backhoe. I have about 3000 into it including getting it towed to my house I’m very happy very excited.
/ Ford 4500 #4
Some info on your loader:
/ Ford 4500 #6
Is it just the angle of your first pic or is the backhoe boom that gigantic! LOL
Can't go wrong for that price.
/ Ford 4500
Still a good purchase. It may be old, but it beats a shovel or renting!
"Old Ford Tractors Just Don't Die!"
I’m new loving it so far it seems to be so much more than Kioti CK 25. I like that one too. I don’t know why I waited till I was 60 till I got a tractor.
/ Ford 4500 #9
15' digging depth backhoe and 3700 lb lift loader. This is industrial. It will pay for itself quickly.
I don't know about Kioti, but i think it would be a farm class loader. The difference between a farm loader and industrial is if you ran into a tree with a farm loader, you'll hurt the loader. If you run into it with an industrial loader, you'll hurt the tree!
Have fun with your toy.
/ Ford 4500
Thanks I will. I feel like a little kid.
/ Ford 4500 #11
I especially like the counter weight quote recommendation on the spec sheet
Please add 5000-6500 lb to the rear of the tractor if not using the backhoe.
So about one new 50 HP MFWD CUT with FEL Hah ha
/ Ford 4500 #12
I own the same one that you have (albeit not as rust free)! learning the 4 valve is tough!
/ Ford 4500 #13
Especially when the controls and pivot points get loose like mine :)
I still smile every time I use the Ford 550 which was a couple days ago. The roof slid all the snow on the horse run out from the barn.
For years we used to hand shovel out pathways. Ugh.
10 minutes with the 755 and it's long reach I can easily do it over the horse fence without even getting inside the run in.
The old Fords are great machines, They may be the best bargains out there.
/ Ford 4500 #14
4 lever control takes practice, but once you get it, it works well.
/ Ford 4500 #15
I was used to running 3 stick Case 580's, first time I ever ran a 4 stick Ford I ABSOLUTELY hated the thing... 50 years later I still do :LOL:.
Wobble sticks are the best thing that ever happened to backhoes IMHO.
/ Ford 4500 #16
Going Case to 4 lever or vice versa, you have to cross your hands as everything is backward depending on your previous experience.
/ Ford 4500 #17
Hmm, on the 4 stick- since you have one ( I am wondering if you would see if mine are set up correctly)
outsides are the stabs
1st - through the 4th.... I am curious first 3 pressed fwd is down out and roll last is left right ( cant remember if push is left an pull is right
/ Ford 4500 #19
Sitting looking at the backhoe, left to right.
#1 Dipper/curl - push goes out, pull curls in
#2 Boom - push goes down, pull comes up
#3 Bucket - push dumps, pull digs or curls up
#4 Swing - push goes left, pull comes right
Outside levers are the stabilizers/outriggers
/ Ford 4500 #20
When I worked on them new we called
Them dinosaurs
But great digging dinosaurs. Designed to trench by using the dipper to dig rather than the bucket to scoop like an ice cream scoop.
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
Electric Concrete Mixer (A61166)
Electric Concrete...
2020 DRAGON ESP...
2016 Dodge Grand Caravan van (A61569)
2016 Dodge Grand...
New/Unused AGT SDA-140W Wheel Loader (A61166)
New/Unused AGT...
207283 (A52708)
207283 (A52708)
