Ford 4400 Double Hydraulic Remote Info Needed
   / Ford 4400 Double Hydraulic Remote Info Needed #1
DonovanC
Ford 4400
Does anyone know if its posible to install a hydraulic remote on a 4400. Asking cause everything i see is a 4 bolt mounting set up. When the actual lift cover block off plate is a 5 bolt system. Last thing i would like to get done due to having it as a usable Tractor.
D4014C
OH18B
*C281244*
1970 4400
   / Ford 4400 Double Hydraulic Remote Info Needed #2
Call this place Meyer ward tractor
Have a bunch of used stuff
(559) 824-0558
   / Ford 4400 Double Hydraulic Remote Info Needed #3
According to the parts catalogs, it takes the same hydraulic valve as all of the thousand series tractors. OEM part numbers: 83944762, D7NNB950B, E2NNB950CA
   / Ford 4400 Double Hydraulic Remote Info Needed #4
Beautiful tractor!!!!
It is a four bolt setup for the original Ford valve(s) and some of the aftermarket ones. One here used:
Gannon/McGee valve used five bolts. One here with four valves, but most were two or three valves:
Myer Ward in California as mentioned, Alexander Tractor in Texas, Abilene Machine in Kansas and many other salvage yards would have used valves to keep it original.
2014 Nissan Pathfinder SUV (A55853)
2014 Nissan...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2025 Electric Cart (A55853)
2025 Electric Cart...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
JCB 409T4 WHEEL LOADER (A52707)
JCB 409T4 WHEEL...
