Ford 4000 will not start
   / Ford 4000 will not start #1
Richard49
Will not start acts like there is no fuel. It has a new injector pump. Would start a first using ether and will fire now using ether. Will injectors or glow plug cause it to act like this?
Yes it has been running. Just started this issue.
   / Ford 4000 will not start #4
Test your glow plug connections for loose wires and ohm the plugs to make sure they are working. You can test voltage to the plugs to see if you are getting correct voltage.
   / Ford 4000 will not start #5
New fuel pump as in rebuilt or new as in aftermarket? Today's fuel is dry. You need an additive for lube in those older tractor fuel pumps An ounce of engine oil to the gallon of fuel helps.
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2017 Kubota L4701 (A57148)
2017 Kubota L4701...
(INOP) HONDA RIDING MOWER (A58374)
(INOP) HONDA...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
TANK MANIFOLD (A58214)
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
