Ford 4000 will not start
   / Ford 4000 will not start #1
Richard49
Will not start acts like there is no fuel. It has a new injector pump. Would start a first using ether and will fire now using ether. Will injectors or glow plug cause it to act like this?
Yes it has been running. Just started this issue.
   / Ford 4000 will not start #4
Test your glow plug connections for loose wires and ohm the plugs to make sure they are working. You can test voltage to the plugs to see if you are getting correct voltage.
   / Ford 4000 will not start #5
New fuel pump as in rebuilt or new as in aftermarket? Today's fuel is dry. You need an additive for lube in those older tractor fuel pumps An ounce of engine oil to the gallon of fuel helps.
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
14C SCRAPER (A58214)
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
2016 Case CX55B Midi Excavator (A55973)
2016 Case CX55B...
