Ford 4000 will not start
   / Ford 4000 will not start #1
Richard49
Will not start acts like there is no fuel. It has a new injector pump. Would start a first using ether and will fire now using ether. Will injectors or glow plug cause it to act like this?
Yes it has been running. Just started this issue.
   / Ford 4000 will not start #4
Test your glow plug connections for loose wires and ohm the plugs to make sure they are working. You can test voltage to the plugs to see if you are getting correct voltage.
   / Ford 4000 will not start #5
New fuel pump as in rebuilt or new as in aftermarket? Today's fuel is dry. You need an additive for lube in those older tractor fuel pumps An ounce of engine oil to the gallon of fuel helps.
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
2013 Case IH Magnum 315 MFWD Tractor (A50657)
2013 Case IH...
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A51039)
2019 Energreen EVO...
