Ford 4000 Throttle flies wide open
   / Ford 4000 Throttle flies wide open #1
phatsupratt
I have a 60's Ford 4000 and whenever slightly more power is needed, the hand throttle flies wide open. I'm forced to drive around with one hand on the wheel and one on the throttle which is annoying.
I assume there is an adjustment somewhere. I'd appreciate any info or diagrams you could point me to.
Thanks,
Mark
   / Ford 4000 Throttle flies wide open #2
would be great to know if this is a 3 cyl or a 4 cyl. in any case, yes.. there is a tension disc.
should be kinda obvious.. but you follow the throttle rod and on the 3 cyl, just under the cowl is a nension nut you can get to with a wrench without removing that cowl.
on the 4 cyl.. same deal.. follow the rod .. you will then see a bellcrank on the top of the bellhousing with a friction disc and castle nut and toothed spring washer. should also see a gov scomp spring.
soundguy
2009 MACK CXU613 DAYCAB (INOPERABLE) (A50854)
2009 MACK CXU613...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
Hayrack (A50515)
Hayrack (A50515)
2008 Dodge Ram 1500 (A50515)
2008 Dodge Ram...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
