Ford 4000 Throttle flies wide open
   / Ford 4000 Throttle flies wide open #1
phatsupratt
I have a 60's Ford 4000 and whenever slightly more power is needed, the hand throttle flies wide open. I'm forced to drive around with one hand on the wheel and one on the throttle which is annoying.
I assume there is an adjustment somewhere. I'd appreciate any info or diagrams you could point me to.
Thanks,
Mark
   / Ford 4000 Throttle flies wide open #2
would be great to know if this is a 3 cyl or a 4 cyl. in any case, yes.. there is a tension disc.
should be kinda obvious.. but you follow the throttle rod and on the 3 cyl, just under the cowl is a nension nut you can get to with a wrench without removing that cowl.
on the 4 cyl.. same deal.. follow the rod .. you will then see a bellcrank on the top of the bellhousing with a friction disc and castle nut and toothed spring washer. should also see a gov scomp spring.
soundguy
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
1 guard rail (A49346)
Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
Case 84in...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
