Ford 4000 Throttle flies wide open
   / Ford 4000 Throttle flies wide open #1
phatsupratt
I have a 60's Ford 4000 and whenever slightly more power is needed, the hand throttle flies wide open. I'm forced to drive around with one hand on the wheel and one on the throttle which is annoying.
I assume there is an adjustment somewhere. I'd appreciate any info or diagrams you could point me to.
Thanks,
Mark
   / Ford 4000 Throttle flies wide open #2
would be great to know if this is a 3 cyl or a 4 cyl. in any case, yes.. there is a tension disc.
should be kinda obvious.. but you follow the throttle rod and on the 3 cyl, just under the cowl is a nension nut you can get to with a wrench without removing that cowl.
on the 4 cyl.. same deal.. follow the rod .. you will then see a bellcrank on the top of the bellhousing with a friction disc and castle nut and toothed spring washer. should also see a gov scomp spring.
soundguy
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
