Ford 4000 power steering question
   / Ford 4000 power steering question #1
shawn1201
luling, Louisiana
ford 4000
Good evening,
Ford 4000, 3 cyl diesel, 8 speed... I have the add on power steering with the power steering tank above the pump. I will be changing the two power steering hoses and to the cylinder tomorrow morning. After I replace them is there anything special I need to do to remove the air from them like bledding the hoses. If so , how is it done. Thanks
   / Ford 4000 power steering question #2
Cycle the steering lock-to-lock a few times, checking the oil level in the reservoir as you go. If you can jack the front end up all or even part way, that will help.
   / Ford 4000 power steering question #3
Good evening,
I don't know about your specific pump but just excercising the power steering will usually clear the air out of the lines. Normally there is no special bleeding procedure.
Thanks guys, I'll change the hoses in the am then
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
377669 (A51573)
377669 (A51573)
CAT Skid Steer Grapple (A51573)
CAT Skid Steer...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
