Ford 4000, only Idles
/ Ford 4000, only Idles #1
kenhillak
Willow , Alaska
ford 4000
I have a Ford 4000, diesel 3 cyl that I am putting back together after a ring job. I have it running but it will only idol, 700rpm or less. When i give it more fuel it runs very poorly, boggs down, black smoke and will not go over 1000rpm. I have overhauled the injectors, and injector pump. all new fuel filters and clean fuel. As far as pump timing I just set it at the 0 mark, if it idols nice, does it still need more timing. Or could it be my injector pump needs re overhaul?. Any thoughts Thanks KEN
/ Ford 4000, only Idles #2
G'day check on what the correct timing should be 0 deg does not sound right it should be more like 25btdc. I will check at work to see if I have a book on them and post back.
Oh and :welcome:
Jon
Thanks so much for the reply. I found the problem, when I was doing the ring job I stuck a rag in the intake so i wouldent stupidly drop anything in there. go figure. so once the rag was removed all worked as it should. KEN
