Ford 4000 engine running away
   / Ford 4000 engine running away #1
beggar
picayune,ms.
farmtra555-case1494-kubota M4050-F4610-MF285
My cuz ask me to post this. He's got a 1964 ford 4000 diesel 4 cyl. that revs up and runs away when it's cold but quits when it warms up. the throttle lever loses any drag on it as it revs up.
It has a rossa master pump on it that was rebuilt about a year ago and has been working fine. the tractor runs good but he's is afraid to leave it to go open a gate or leave it when it's cold because it's subject to engine running away. There is a return line from the injectors and a return line from the injector pump going to a single fitting at the bottom of tank. does anybody know
if it has a check vale in it that could cause it. Strange that it goes away after the engine warms up. it's like a vaccum sucking the throttle open. Any help appreciated
   / Ford 4000 engine running away #2
Sounds like your governor ring in the injection pump is messed up
   / Ford 4000 engine running away #3
Meteringvalve sticky due to water in fuel...be carefull for enginrunning away and exlode ! Do the inj pump again and clean fueltank
   / Ford 4000 engine running away #4
May be run some sea foam or stanadyne or some other additive to the fuel for lubricity and see it it helps.
   / Ford 4000 engine running away #5
Remove the side cover on the pump & hold a wad of paper towels under the flow.. look for black coffee ground looking particals.. that's broken flex ring pieces.. If nothing found, pull the top cover and have a look inside..
Pull the dipstick & check for fuel in the oil also..
It sounds like the flex ring has broken again.. pump repair will be required again.. I can help w/ that..
Thanks to everybody for you comments. we thinking about trying to run some lube in the fuel for a start and see what that does. you know , try the easy stuff first.
10' Feed Bunk (A50515)
2020 CF Moto 500 Trail (A50514)
2020 CF Moto 500...
Barn Wood Bar Table (A50515)
Barn Wood Bar...
Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
Lull Highlander...
Sudenga 10-72 Swing Away Auger (A50514)
Sudenga 10-72...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2016 JOHN DEERE...
