Ford 3910
   / Ford 3910 #1
richlahmers
ford 3910
my Ford 3910 sat all summer with a new battery(spring 2011) & now it won't even start to turn over! Checked battery & it was holding 12.47 volts! It ran fine when I put it away! I'm lost!!!
   / Ford 3910 #2
Did you clean the terminals? Its possible its corroded or one of the terminals isn't making good contact.
   / Ford 3910
yes I cleaned the terminals, also the dash & the headlights work! That's why I'm confused!?!
   / Ford 3910 #4
check to make sure the high low lever is in neutral there is a safety switch on that lever and you might try wriggling it while trying to crank it
   / Ford 3910 #5
rich: Have you tried to jump it with other tractor/truck with known good battery? My tn had the same problem, would just click starter. Checked voltage, and it looked good. Jumped it and it would charge up slightly, and then maybe start 1 time. wouldn't next. New battery cured problem. :thumbsup:
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52128)
2017 Ram 5500...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Great Plains Nutri-Pro NT-30 Nh3 Applicator (A50514)
Great Plains...
2023 JOHN DEERE 50G EXCAVATOR (A51242)
2023 JOHN DEERE...
UNUSED FUTURE MINI EXCAVATOR AUGER SET (A51244)
UNUSED FUTURE MINI...
