Ford 3910 no HYD Remotes?
   / Ford 3910 no HYD Remotes? #1
polaris500
North West PA
Ok i just picked up my 3910 and there are no hyd Remotes on it.
I would like to add some, What all do i need to do to make this happen? Im waiting on a owners manual and service manual to come in so i got no reference to anything right now..
Also on the right and side right below the 3pt Levers There is a little black know one side marked F and other S what is this for? I have never seen anything like this on any of my tractors. i Tried turning it but it wouldn't budge
   / Ford 3910 no HYD Remotes? #2
There are several remote hydraulics options for the 3910. One of them is shown in the attachment below. It is a dual system, but I think there are single remotes available. I have no idea what the price is, but I'm sure they are not cheap. New Holland remote hydraulics kits are elegant and well made.
Ouch I never thought a price like that. Maybe ill just stick to no putting them on here and just use the 1066 for anything i need hydraulics.
   / Ford 3910 no HYD Remotes? #5
The knob is the lift rate adjustment. Fast-slow. Few people use it/or know why it's there, so they seize. Usually the knob is broken off from trying to free it
   / Ford 3910 no HYD Remotes? #6
try gettin a valve from a salvage yard call gulf south equipment they should have a good used one
   / Ford 3910 no HYD Remotes? #7
How true but most people don't seem to use ground-engaging implements with their tractors any more. By the way, mine is free and moves easily. ;)
Polaris- It would be cheaper to add a pump driven off the front of the crank and make your own lines and add valves. My 3910 didn't come with an aux pump or valve body either. When I checked the prices of factory equipment, even used, it was more than I wanted to spend on a 24 year old tractor just to have rear remotes. If you're handy at fabrication, the brackets are easy to make. It will also let you choose the pump capacity if you choose to add a FEL later.
Ok i found some but now i need to know weather i need
non-detent
or pressure detent
Whats the difference and what is the best choice
   / Ford 3910 no HYD Remotes? #9
non-detent
or pressure detent
Non-detent, let go of the handle, it springs back to neutral.
Pressure detent, move the handle, it will stay in position until a certain (should be adjustable) pressure is reached, then it springs knack to neutral.
   / Ford 3910 no HYD Remotes? #10
and base that on application. IE> I wouldn't use a detent on a loader.. etc..
soundguy
2011 Toyota Sienna Van (A50324)
2011 Toyota Sienna...
2018 JOHN DEERE 333G SKID STEER (A51242)
2018 JOHN DEERE...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
2021 SELLICK S80J4E-4PS ROUGH TERRAIN FORKLIFT (A51242)
2021 SELLICK...
CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51243)
CASE IH 580...
