Ford 3910 Brakes
   / Ford 3910 Brakes #1
JimmyAAA
Fort Wayne, Indiana
Ford 3910
Hello,
I have a 1987 Ford 3910. When I lock the brakes to turn, either left or right, there is a shuddering noise. This tractor is 29 years old. It runs good. I understand the brakes run in oil. Could the brakes need attention? What happens if I do nothing? The brakes still work fine. What would be the cost to repair this problem?
Thanks,
JimmyAAA
   / Ford 3910 Brakes #2
Change the hydraulic oil and filter[both if it has 2]. Low spec and/or contaminated oil can cause brake chatter. Use New Holland 134 oil, New Holland Mastertran Ultraction, or CaseIH Hytran Ultraction. There are good generic equivalent oils out there as well as inferior crap posturing as OEM oil replacements.
   / Ford 3910 Brakes
Thank you, Sir. I'll try that.
Jim
   / Ford 3910 Brakes #4
FYI. You may still see the issue though. I have two 3910's and 4600 and a 2810. All make this sort of noise but at slightly different levels. No real issue though but do. Change the oil as it probably will be better than it is now. These brakes are awesome and last forever but can make some noise. Good luck.
   / Ford 3910 Brakes
FYI. You may still see the issue though. I have two 3910's and 4600 and a 2810. All make this sort of noise but at slightly different levels. No real issue though but do. Change the oil as it probably will be better than it is now. These brakes are awesome and last forever but can make some noise. Good luck.[/QUOTE
Thank you, Sir!!
   / Ford 3910 Brakes #6
My 3910 is an 84. Brakes are very smooth and effective.
Rick is a reliable source of information. Give the oil change a try.
Welcome to TBN. Post pics of your tractor when ya get a chance.
   / Ford 3910 Brakes #7
Are you using the brakes to turn assist? All my tractors brakes are quiet unless I use them to turn tight. Then they can make a little noise. This is normal.
   / Ford 3910 Brakes #8
If after the oil, filter change and running it for a few hours the chattering still exists, go to the New Holland dealer and buy a gallon of anti-chatter 251403. Pour all of it in the rear axle. $65, but quites the brakes.
   / Ford 3910 Brakes #9
Totally even on right tight turns?
Massey Ferguson MF6500 (A57148)
Massey Ferguson...
48in Boom Lift Basket (A56857)
48in Boom Lift...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
(10) UNUSED SDLANCH 2.5CMX3M RATCHET STRAPS (A58375)
(10) UNUSED...
Giyi Mini Grapple (A57149)
Giyi Mini Grapple...
Honda UTV (A56859)
Honda UTV (A56859)
