ford 3610 removing fuel pump seems to be stuck
   / ford 3610 removing fuel pump seems to be stuck #1
stevebb1
stilwell kansas
ford 3610
Hi all and thank you for stopping in.
I'm removing the fuel pump and replacing with a new one but it seems to be stuck to whatever it goes into .. which is where I put oil into the tract or and I can see when I look down into the oil filling hole (sorry I don't know the proper terms for this stuff) . .. but anyways I can see a gear in there is moving around when I move the fuel pump around .. and obviously that is what the fuel pump is stuck on ...
Another way to describe it is the fuel pump goes into a hole but when I try to take it out there is a gear stuck on it that is bigger than the hole the pump went into .. so how do I get free from that gear? Or is that the problem?
so can you guys tell me where I should go from here? And please don't tell me to hire a mechanic, tried that and if it had worked out well .. I wouldn't be here now.
I have another ford tractor that I steal parts off of .. and I tried taking the fuel pump off of it and it is acting the very same way, like its stuck with that gear on it. So I suspect then that I haven't gone far enough to get the fuel pump free .... but I can't figure out what it is that I need to do to solve my problem. - or they're both screwed up in the same fashion.
Thanks again for your input.
Okay I figured out I needed to take off the cover of the area where I put in the oil and then there are 3 bolts still holding the fuel pump in place.
and I see the gear is suppose to be loose to an extent (or that was my conclusion) so now I am just waiting on the fuel pump to get here. :)
   / ford 3610 removing fuel pump seems to be stuck #3
The trick to this is.. ask BEFORE starting a project like this.. and its called an INJECTION PUMP..
Do you have the SIMMS PUMP or a CAV pump?? On the Simms, the injector lines come off the pump, in a straight line.. The CAV are in a circle.
Why did you get ANOTHER pump?? Unless yours is seized, it could have been rebuilt..
   / ford 3610 removing fuel pump seems to be stuck #4
He has a CAV pump. "Here" it can be less expensive to buy and install a repop CAV pump than have a pump shop "rebuild" an OEM CAV rotary.
LOT NUMBER 51 (A53084)
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A53472)
Adams Load Out...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53472)
Quick Attach Skid...
