Ford 3600 Clutch Identification.
   / Ford 3600 Clutch Identification. #1
zombielinux
1976 Ford 3600
So I've got a Ford 3600 that needs a new clutch.
Symptoms:
Will start in neutral.
Gears will grind when trying to put it into gear or engage the PTO.
Clutch linkage cannot be shortened any more.
I am able to put it into/take out of gear if I bend clutch linkage to shorten the overall length, so I know its not stuck.
With that being said, I've noticed there are quite a few different dual stage clutches available from the usual suspects, all slightly different.
Attached is my identification plate, but I'll transcribe it here as well:
Tractor Number: C522259
Model: CA213C
Unit: 6L30B
Engine: 6J29A
Transmission: 6L04C
Rear Axle: 6K22C
Hyd. Pump: 6K07A
Hyd. Lift: 6H31B
From a different forum, I've been given the decoded model/unit information: CA213C
CA2 = 3600 1976-1981
1 = Diesel
3 = Live 540 rpm
C = 8x2 speed manual (4x1 + hi/low)
Unit = Built November 30, 1976 second shift
If anyone can provide any additional information about this new-to-me tractor, I'd be very appreciative.
   / Ford 3600 Clutch Identification. #2
I don't know about that tractor but, if it has an inspection cover you may be able to adjust the release fingers and get a couple more yrs out of it. I did this on a 445 long I owned. When it finally started slipping I sold it and told the buyer it needed a clutch.
If I were in your shoes and going to replace it myself I'd split it first and make sure I got the correct clutch. Especially if you're going to order it online.
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
Entyre Chip Spreader (A51573)
Entyre Chip...
Generac Generator (A51691)
Generac Generator...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
