Ford 3550 Hydraulic Fluid/Filter Change gone wrong already
   / Ford 3550 Hydraulic Fluid/Filter Change gone wrong already
I stand corrected. You're right, 23 is the bolt. I like the idea of welding a nut onto the bolt after soaking and heating.
Thanks everybody. I'll let you know how it turns out (no pun intended).
   / Ford 3550 Hydraulic Fluid/Filter Change gone wrong already #12
When you weld the nut to the bolt, just don't connect your ground to the frame rather than the nut, you don't want to weld the bolt to the threads. (Don't ask how I know).
Holy smokes. Thanks everybody for your help. I finally ended up having to drill it out and tap new threads. It made me nervous, but it seems to be holding just fine. I've only got three bolts holding it in for now but nothing is leaking so I'm pretty happy.
2018 Kubota U17 (A53317)
2018 Kubota U17...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A58018)
2020 FREIGHTLINER...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2021 KENWORTH T680...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
2022 Caterpillar 300.9D Mini Excavator (A55973)
2022 Caterpillar...
2016 PETERBILT 579 (A58214)
2016 PETERBILT 579...
