Ford 340A very little power
   / Ford 340A very little power #1
motodude4
Tomball Tx
John deere 820, 5165E. Massey Ferguesom 383. Ford 340A, 3400, 3600, 4630. International 484
Hey Everyone, I would like your opinions.
1983 Ford 340A tractor. 3000+ hours. My father in law bought it, and I have been struggling to get it "useable"
History of what I did, I flushed the fuel tank, changed the fuel filter (had rust and sediments on both sides of the filter medium), completely drained and re primed the diesel injection system. put a new battery on it. Also changed the transmission fluid (which was full of water). previous owner just changed engine oil. go figure...
When he bought it, it had so little power that it would not even move in high range. we loaded it on a trailer in low range, and it barely made it up the ramps without bogging down. After all the work I did, with fresh diesel in it, now you can use high range, but you really have to have a heavy foot to get it going. Its not user friendly at all. We have several other Ford tractors, and none of them are as gutless as this one.
My question is, do you think that I should try and replace the injectors? I'm just now sure how much damage so much crap in the fuel lines will do to injectors, or for that measure, the injection pump.
As far as compression, I haven't tested it, but it cranks fairly easily now.
Just to give you an idea of the power issue, if you raise the front bucket up at idle, the tractor will bog down and die.
   / Ford 340A very little power #2
You are right in thinking that the problem is injection related. Start with taking the injectors out and have them tested. This is the cheapest route to finding out if the problem is crud related. The diesel shop can tell you whether the pump may need to be checked out too.
By the way, when it bogs, it doesn't smoke I assume?
No, no smoke at all when it bogs.
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
John Dozer JD650 (A51691)
John Dozer JD650...
2007 HONDA TRX250 RECON ATV (A51247)
2007 HONDA TRX250...
2007 Mack Winch Truck (A53117)
2007 Mack Winch...
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
Frontier GM1084 (A50123)
Frontier GM1084...
