Ford 3400 primary clutch not disengaging properly
   / Ford 3400 primary clutch not disengaging properly #1
bvergeer
Maryville, TN
1974 Ford 3400
I bought it last weekend and I'm still trying to figure things out. Anyway, it is a 1974 3400 with loader. Today I learned that it has a dual clutch setup to support the 540 pto. I think the trans is called a 6/4 with the dual reverse.
The issue: Sometimes, usually when cold in 1st/low, when I depress the clutch it doesn't disengage until press the clutch as far as possible and hammer the brakes. Once warm, all seems well, the main clutch disengages at about the 3/4 mark. I've adjusted the clutch and have about 1.5-2" of free play.
Any suggestions?
I need to check/fill the cases as well. Are the level plugs the 2 square nut plugs on the right side?
Thanks,
Bob
Resolved. The weep hole was plugged and close to a quart of crap drained out. Seems to be getting better with time.
   / Ford 3400 primary clutch not disengaging properly #3
When not in use, keep the clutch pedal blocked down to keep the pressure plate off of the disc. Let it "dry" up. In fact its not a bad idea to block the clutch any time the tractor is not to be used for a period of time.
5004 (A55851)
5004 (A55851)
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2025 Wolverine MAD-12-12D Auger Mini Skid Steer Attachment (A56857)
2025 Wolverine...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
2020 DRAGON ESP...
