Ford 3400 primary clutch not disengaging properly
   / Ford 3400 primary clutch not disengaging properly #1
bvergeer
Maryville, TN
1974 Ford 3400
I bought it last weekend and I'm still trying to figure things out. Anyway, it is a 1974 3400 with loader. Today I learned that it has a dual clutch setup to support the 540 pto. I think the trans is called a 6/4 with the dual reverse.
The issue: Sometimes, usually when cold in 1st/low, when I depress the clutch it doesn't disengage until press the clutch as far as possible and hammer the brakes. Once warm, all seems well, the main clutch disengages at about the 3/4 mark. I've adjusted the clutch and have about 1.5-2" of free play.
Any suggestions?
I need to check/fill the cases as well. Are the level plugs the 2 square nut plugs on the right side?
Thanks,
Bob
Resolved. The weep hole was plugged and close to a quart of crap drained out. Seems to be getting better with time.
   / Ford 3400 primary clutch not disengaging properly #3
When not in use, keep the clutch pedal blocked down to keep the pressure plate off of the disc. Let it "dry" up. In fact its not a bad idea to block the clutch any time the tractor is not to be used for a period of time.
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
1265 (A50490)
1265 (A50490)
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
2018 Ford F-150 (A51039)
2018 Ford F-150...
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
2008 Ford F450 (A49461)
2008 Ford F450...
