Ford 3400 compression
/ Ford 3400 compression #1
jswolfe29
Sterling, MA
Ford 3400
Good evening.
Newbie with a 1974 Ford 3400 3-cyl diesel industrial tractor that won't start. I replaced the battery, fuel filter and fuel. Turns but doesn't catch even with ether. I suspect not enough compression. Front loader and backhoe are dug in, so pull starting is not an option.
What would be my next step in debugging and repairing?
Thanks
/ Ford 3400 compression #2
Welcome to TBN!
Had it been running? When was the last time it ran?
You could check the valve adjustment first. 0.014-15" intake, 0.018-19" exhaust
Thanks for your reply. Glad to be here.
It had been sitting for a few months. Previous to that, running okay. Where would I check valve adjustment? Sorry, really a newbie to engine maintenance/repair.
/ Ford 3400 compression #4
Isn't there someone locally who is knowledgeable and can come over to help you?
/ Ford 3400 compression #5
Well, here is a video that is pretty good on this engine. You will probably need the cork valve cover gasket (C7NN6584B)
/ Ford 3400 compression #6
Good evening.
Thanks
In that predicament I would check to see if the fuel is getting to the injectors at least. I know either should do it but anything can happen. I would also make sure the kill choke is not on. Other than that I would have to get a professional
/ Ford 3400 compression #7
U definitely have to make sure that fuel is making it TO the injection pump inlet..
There is a bleed screw by the nameplate on the pump..
Its a double screw, with a 5/16 wrench needed ..
U loosen the screw and spin the engine.. fuel should shoot out of the bleed screw with no bubbles..
Once u get fuel there, tighten the bleed screw and move onto the injectors..
Follow the steel lines up to the injectors that are in the head..
Loosen the steel lines a couple of turns.. no need to take them off..
Pull the throttle to wide open and crank the engine..
A few 8 second blasts from the starter should produce some fuel at the loosened lines at the injectors..
If nothing.. time to call in the pros..
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
Dodge Charger (A64557)
