Ford 3000
/ Ford 3000 #1
transformed
John deere 770
I was gifted a gas ford 3000. Unknown what year it is, but the previous owner said it ran when parked.
But I will be using it with my metal recycling business. I currently have a John Deere 770 4x4 but with its hydraulics are not working it's best,I need a little more lifting capacity.
When receiving a new to you old tractor, what is your first item on your reviving list?
I guess to see if the motor is frozen.
/ Ford 3000 #2
Do your best and get it to run or try to start. Battery/starter will be first. My NTM 2000 CL. needed TLC. was comical. It did run was true. Barely, And about it to!!
/ Ford 3000 #3
Pull the oil drain plug and see if any water comes out.
/ Ford 3000 #4
Some WD 40 sprayed into each cylinder before you try to start it. While the plugs are out check for spark. I had a gas 2000 some years back - a decent little tractor for what it was
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
WHOLE PART ROOM (A68842)
WHOLE PART ROOM...
1991 26ft Pursuit 2350 Walking Around Cabin Cruiser with 2017 21ft S/A HMDE Performance Boat Trai... (A66738)
1991 26ft Pursuit...
1998 KENWORTH W900 TRIAXLE (A67714)
1998 KENWORTH W900...
