3-Point Hitch ford 3000 three point
   / ford 3000 three point #1
trentonford3000
glencoe mn
ford 3000
I have a ford 3000 with a three point that will raise all the way to the top even though the lever is only 3/4 of the way up but below that works properly and no the draft control is not on. any help will be greatly appreciated:confused3::tractor:
   / ford 3000 three point #2
A few more details will help. I am not really familiar with that model, but more details may help others...
First, did it just start doing it all of the sudden, or has it been that way?
Second, is this only with an implement on, no implement, or all of the time??
Third, when it goes all of the way up, and you move the lever beyond 3/4 to full up, does it sound like it is still trying to raise and making the pump go into relief?? or is it just nothing??
Could be something as simple as a quadrant adjustment, or it could be something screwed up inside.
It has been doing it since i bought it last winter. it does it with or without an implement and it does it all the time. and no ot does not sound like the pump is still trying to lift any higher it doesent do anything.
   / ford 3000 three point #4
without pulling the lift cover you may never know. might be something as simple as someone welded up the cam follower pin or cam and exagerated it so that it reaches thrshold before the lever is up.
the piston unloads / turns off the hyds flow when it reaches stroke via linkage... so since you do not hear pump / relief strain. THAT is working fine.
I foregot to add the three point doesent raise past that 3/4 mark and then it will raise all the way to the top. What do you suggest just live with it?
   / ford 3000 three point #6
already told you what i thought.. :)
Thankyou for your help I think i will just live with it:thumbsup:
   / ford 3000 three point #8
it's not difficult to pull the top cover...
   / ford 3000 three point #9
Pull the cover and investigate, these tractors are simple.
Do you just take all of the bolts out? it has a loader ran off of the tractor hydraulics does this complicate things? is there a gasket to worry about? what would i be looking for (what does it look like)? it will b probably be a couple of days i am busy with random stuff
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
1998 CATERPILLAR D5M PIPE LAYER (A50854)
1998 CATERPILLAR...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A49461)
2012 Vermeer...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
