ford 3000 starting
/ ford 3000 starting #1
forester76
Bridgeport, WV
Ford 8N/3000
I have a 1974 3000 gas. Spark was weak so I replaced points, condensor and rotor. Spark was greatly improved, BUT, when I try to start it, it backfires through the carb and will not start. HELP!!
/ ford 3000 starting #3
It sounds as though your timing is way of. Check to be sure your firing order is correct and number one cylinder on the engine is number one on the distributor. Check the gap on your points to be sure it's where it's supposed to be. You can then get your timing pretty close by static timing the engine.
/ ford 3000 starting #4
180º out on the cap..??
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
MQ Power MQP80IV Industrial Generator (A64912)
MQ Power MQP80IV...
2009 FORD E150 CARGO VAN (A66091)
2009 FORD E150...
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
2007 BIG TEX 20 T/A UTILITY TRAILER (A67714)
2007 BIG TEX 20...
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
