ford 3000 starting troubles
   / ford 3000 starting troubles #11
OUCH! Grinding for-ever- who said anything about that? Most engines now only recommend 30 seconds or less cranking. Have you ever seen a towed tractor collide with the puller.???
is it a standard gear model? if yes.. pull start it. you'll hurt it more grinding on it forever till the solder spins out of that 100$ core, 180$/replace starter.
PS.. it's fun to get to the 3rd starter bolt on a 3000D.. plan on taking the fuel filters and lines off and getting the battery and tray out of the way.. not to mnetion the steering arm is quite a bit in your way too...
soundguy
   / ford 3000 starting troubles #12
if he's having problems bleeding and starting it.. I forsee lots of starter usage. don't need to be a jedi for that one.
colide with the puller? no.. I havn't seen it. down here where i live we use the clutch and or clutch/brake.. or if it gets really bad.. the fuel kill / ignition off control. :(
that and a safe length tow strap and you should be good... yer gonna be near ridding the clutch to pop her off anyway..
soundguy
   / ford 3000 starting troubles #13
soundguy
Okay, you win, what happened to the legal disclaimer? Sure enough, he has been on that starter, to bleed down the system, with several attempts before I wrote him. I hope we see from the OP the solution to it..I was unable to tow either of my Automatics....Jy.
   / ford 3000 starting troubles #14
yep.. he will have to have a manual gear tranny.. no sos.. etc.
pull starting has saved many a starter from a early death...
soundguy
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
(INOP) JOHN DEERE 790 TRACTOR (A51243)
(INOP) JOHN DEERE...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
(14) Round Alfalfa Bales (A50515)
(14) Round Alfalfa...
