Ford 3000 Starting Issues? Having to hotwire currently
   / Ford 3000 Starting Issues? Having to hotwire currently #1
SupaMav68
Ford 3000, Farmall Model A
Howdy Everyone-
First time on here. I have a gas Ford 3000 that is having starting issues. I replaced the ignition switch, points, condensor, coil, plugs and wires. The tractor turns but will not start. I have fuel. I'm currently having to hotwire the tractor (battery jumper to coil) to get it to run. Does anyone have any idea what my problem could be?
   / Ford 3000 Starting Issues? Having to hotwire currently #2
Does it perhaps have an open ballast resistor?
No, It doesn't look to have a ballast resistor.
   / Ford 3000 Starting Issues? Having to hotwire currently #4
are you getting 12v from the wire to the coil when the key is on? i would start there.
   / Ford 3000 Starting Issues? Having to hotwire currently #5
With the key on you should read twelve volts on one side of the coil. With the points open you should read twelve volts on both sides of the coil. When the points close you should continue to have twelve volts on one side of the coil but the other side should be zero.
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
1997 Mercedes Convertible (A48082)
1997 Mercedes...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
NEVER USED FECON 74in Deck Mulcher FDM74 (A51039)
NEVER USED FECON...
