Ford 3000 stalls on steep hill
   / Ford 3000 stalls on steep hill #1
Shepp
Toronto Ontario
Ford 3000
Hello: i have a Ford 3000 diesel that starts fine, but when it gets on a hill she slowly loses rpm and acts like she is running out of fuel then quits. After I roll back down the hill I can start her again after a lot of cranking. It has a quarter tank of fuel. Could it be sucking water off the bottom maybe?
   / Ford 3000 stalls on steep hill #2
It could be many things. Can you see water in the tank?
When was the last time you replaced the fuel filter?
By starting after a lot of cranking sounds like it may be loosing prime. I forget does it have a lift pump that may be or have failed?
   / Ford 3000 stalls on steep hill #3
How steep is the hill? If your tractor is gravity fed fuel you may need to go up the hill with a 3/4 tank or more. The fuel pickup might be above the fuel line on the slope with only 1/4 full. Another thing to try is backing up the hill. Running out of fuel is a pain in the a*s.
That must have been it. After I put 2 more gallons of fuel in and some fuel conditioner the problem went away. The fuel gauge is busted so maybe she was lower then I thought.
   / Ford 3000 stalls on steep hill #5
I am glad you got it running. When you need the tractor, you need it to run. Last winter I had a starting problem with mine when there was a foot of snow on the driveway. I had to jump the starter because the ignition switch was bad. I almost got an ulcer. I put in a new switch after that.
   / Ford 3000 stalls on steep hill #6
Glad you found the issue.
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
Informational Lot - Financing (A53473)
Informational Lot...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
