Ford 3000 stalls on steep hill
   / Ford 3000 stalls on steep hill #1
Shepp
Toronto Ontario
Ford 3000
Hello: i have a Ford 3000 diesel that starts fine, but when it gets on a hill she slowly loses rpm and acts like she is running out of fuel then quits. After I roll back down the hill I can start her again after a lot of cranking. It has a quarter tank of fuel. Could it be sucking water off the bottom maybe?
   / Ford 3000 stalls on steep hill #2
It could be many things. Can you see water in the tank?
When was the last time you replaced the fuel filter?
By starting after a lot of cranking sounds like it may be loosing prime. I forget does it have a lift pump that may be or have failed?
   / Ford 3000 stalls on steep hill #3
How steep is the hill? If your tractor is gravity fed fuel you may need to go up the hill with a 3/4 tank or more. The fuel pickup might be above the fuel line on the slope with only 1/4 full. Another thing to try is backing up the hill. Running out of fuel is a pain in the a*s.
That must have been it. After I put 2 more gallons of fuel in and some fuel conditioner the problem went away. The fuel gauge is busted so maybe she was lower then I thought.
   / Ford 3000 stalls on steep hill #5
I am glad you got it running. When you need the tractor, you need it to run. Last winter I had a starting problem with mine when there was a foot of snow on the driveway. I had to jump the starter because the ignition switch was bad. I almost got an ulcer. I put in a new switch after that.
   / Ford 3000 stalls on steep hill #6
Glad you found the issue.
Informational Lot - Financing (A53473)
Informational Lot...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
Adams 5 ton Fertilizer Buggy / Wagon (A53472)
Adams 5 ton...
Ford Pickup NR (A50323)
Ford Pickup NR...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
