Check the ground to make sure it is tight and has good contact to clean metal. There is a 3 amp fuse between the key switch and the voltage stabilizer. It could also be the voltage stabilizer. Hope this helps
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
deffinately do check the fuse aft of the cluster... post back..
until you do get it fixed, wire a low wattage lamp from switched power to the oil sender.. switch on, lamp on, engine not running.. engine running lamp off, if you have oil pressure.
