Ford 3000 Leaking from Clutch Shaft
   / Ford 3000 Leaking from Clutch Shaft #1
Bravenrace
As the title states, it's leaking hydraulic fluid from the shaft that the clutch pedal actuates. I can't find anywhere in my factory manual that covers this. What I'm looking for is information on what parts I need and how to do the repair. Its a 1974 3000 gas 8 speed.
Thanks in advance for any help you can provide.
   / Ford 3000 Leaking from Clutch Shaft #2
I assume you mean the clutch and brake cross shaft that goes through the rear center housing.
Not uncommon for the bushings to get worn and/or the seals to go bad and leak.
I have seen badly worn shafts too.
Not a big deal to fix. Drain the oil out of the rear end, remove the step plates and all brake and clutch linkage. Then you can remove the shaft to renew the bushings and or seals.
Pretty obvious what needs to be done once you get your wrenches out and get started.
   / Ford 3000 Leaking from Clutch Shaft #3
Exactly the way ultraD said. I just did mine on my 4000 a month ago. The clutch/break bushings were so worn the pedals were flopping around. The cross shaft (expensive part) and seals were ruined. Surprisingly, the bushings in the trans were good. Almost everything was cheap from the dealer or online. I ended up making the cross shaft, its only 1-1/8 dia. CRS. I wish I would've made it 3/16" longer between the snap rings. I was only able to put one dust cover gasket on, so I put it on the clutch side.
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
2019 FORD TRANSIT 350HD VAN (A52576)
2019 FORD TRANSIT...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53472)
2011 New Holland...
