Ford 3000 Instrument Cluster problem
   / Ford 3000 Instrument Cluster problem #1
davka
Ford 3000
Ford 3000, 1966, 3 cyl, gas: The tractor is clean with no rust and runs great. Of the 5 indicators in the Instrument Cluster, ONLY the generator light works. The oil light, temperature gauge, fuel gauge and tachometer do not work. I want to get these indicators performing again. Any idea if there is a common denominator causing the 4 indicators to not work while the generator light works normally? How would I diagnose this problem?
   / Ford 3000 Instrument Cluster problem #2
The tach and hour meter are cable driven.
The temp and fuel gauges are powered by a voltage stabilizer attached to the rear of the cluster housing. The charge and oil lamps share a common 12v supply.
You have multiple causes for the various concerns.
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A49461)
2017 Wacker Neuson...
2018 INTERNATIONAL LT625 SLEEPER (A51222)
2018 INTERNATIONAL...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
