Ford 3000 hydraulic problem
   / Ford 3000 hydraulic problem #1
John paxton
Wallback,wv
1972 ford 3000
I have hydraulic pressure but no lift.
   / Ford 3000 hydraulic problem #2
With the Draft/Position Control lever set in the Draft (downward) position, engine running, lower links full down, stand on the lower links, pick up the upper link and push it forward to compress the draft control spring. If nothing happens, you have a control valve issue. If the lower links raise, you should be good, or you have a control lever linkage issue.
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
John Deere 7520 (A50120)
John Deere 7520...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel Forks...
