FORD 3000 HYDRAULIC LIFT PROBLEM
   / FORD 3000 HYDRAULIC LIFT PROBLEM #1
LAFARMBOY
Grosse Tete, LA
FORD 3000
I have a Ford 3000 tractor, built in 1968, 7600 hrs. I just overhauled hydraulic lift cylinder; changed cylinder piston seal and backup ring, and most O-rings. The lift does not stay up; have a mower attached. I cannot regulate the height of mower.
   / FORD 3000 HYDRAULIC LIFT PROBLEM #2
Hi and welcome to the forum!
:welcome:
I'm going to move your thread on over to the vintage Ford section. Hopefully someone over there has some insight.
   / FORD 3000 HYDRAULIC LIFT PROBLEM #3
did you replace the cam follower pin and then adjust the lift?
are you in position control or draft mode?
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
40ft High Cube Shipping Container (A51573)
40ft High Cube...
20ft Shipping Container (A51573)
20ft Shipping...
FRONTIER MG20F LOT NUMBER 82 (A53084)
FRONTIER MG20F LOT...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
