FORD 3000 HYDRAULIC LIFT PROBLEM
   / FORD 3000 HYDRAULIC LIFT PROBLEM #1
LAFARMBOY
Grosse Tete, LA
FORD 3000
I have a Ford 3000 tractor, built in 1968, 7600 hrs. I just overhauled hydraulic lift cylinder; changed cylinder piston seal and backup ring, and most O-rings. The lift does not stay up; have a mower attached. I cannot regulate the height of mower.
   / FORD 3000 HYDRAULIC LIFT PROBLEM #2
Hi and welcome to the forum!
:welcome:
I'm going to move your thread on over to the vintage Ford section. Hopefully someone over there has some insight.
   / FORD 3000 HYDRAULIC LIFT PROBLEM #3
did you replace the cam follower pin and then adjust the lift?
are you in position control or draft mode?
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2015 DODGE RAM...
2009 UTILITY TRAILER MFG. CO. SEMI TRAILER 57 (A50854)
2009 UTILITY...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
