Ford 3000 draft control arm
   / Ford 3000 draft control arm #11
Can you post a detailed pic on what is 'broke' on that one?
keyway looks good, flange looks good, metal handle looks good...
   / Ford 3000 draft control arm #12
Don't believe that is his handle, probably found picture on the net.
I have a 3000 lift handle but it doesn't have the hub, just the flat friction area like in the parts drawing posted. What's with the hub, my 71 3000 has the flat version, is this from an earlier tractor?
   / Ford 3000 draft control arm #13
We need to see what he has, not a stock pic.
That is a picture of what I need. I bent/broke the handle while backing up on a downed tree. A limb came in from under the seat, and I didnt see it. I bent the arm and the hieght guage. When I tried to bend these back into place the arm broke and the guage, well I just let it be. Its still bent and could use another also. I have searched all websites, and I find that I dont know the real name of this piece. The book calls it a touch control arm, but I have seen other names for it. I have been using a vice wrench to raise and lower while looking for the part, but again, I cannot find it. The parts houses listed above will not let me "drill down" to the part. I guess I need to find a local guy who has one he is parting out, but I dont see many of those around here. Please let me know if anyone has a lead on this! Thanks!
   / Ford 3000 draft control arm #15
no picture came through.
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
2020 Kinze 3505 High Speed 6/11 Planter (A52128)
2020 Kinze 3505...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
