Ford 3000 draft control arm
/ Ford 3000 draft control arm #1
Runninlate
Cunningham
Craftsman GT5000, Craftsman FS5500
I have a Ford 3000, and I have broken the draft control (touch control) arm off while backing. I need to replace it since I cannot raise and lower the brush cutter without it. I have searched for it on the internet, and I have called the local NH dealer. I cannot seem to find it. My next step is to try to find it on here, and I am wondering if its universal? Can I use the arm off of a 2000, or a 4000 or a later model? My year model is a 73 or 75. I cannot remember exactly. If I need to know exacts please inform. Any help would be appreciated!
Not sure why I didnt receive a response... Seems as if someone would be knowledgeable concerning the lift linkage on a ford 3000, and where to find parts?
/ Ford 3000 draft control arm #3
post a picture for us. lets see exactly what you broke.
/ Ford 3000 draft control arm #4
Like Soundguy said. Post some pictures of the part in question. It sounds like you broke the lift rocker in the back?
Ford Hydraulic Lift Rocker for Ford 3000,3600,3610,4000,4100,4610,4610SU - E2NN535BA
/ Ford 3000 draft control arm #5
pictures will definately help!
I have a photo, but I dont have a copy/paste option or add a photo button. How can I add it from my hand-held device.
/ Ford 3000 draft control arm #7
in the reply box, click go advanced.. from there you can manage attachments.
This is the Arm in which I broke away from the tractor.
I hope this works.
The actual photo is the exact part I am looking for. As you can see its part number 33 on the parts manual, but the image there doesnt represent the actual handle/lift arm. Any ideas?
I hope this works.
I appreciate your patients in my ignorance as to how to post a photo. I finally realized I had to post from my computer and not my handheld phone. I would like to try and find the part for my tractor, and replace it. the guage that holds the arm in place is also kind of bent, but I think that I could work with that. Thanks for your help in advance!
/ Ford 3000 draft control arm #10
/ Ford 3000 draft control arm #11
Can you post a detailed pic on what is 'broke' on that one?
keyway looks good, flange looks good, metal handle looks good...
/ Ford 3000 draft control arm #12
Don't believe that is his handle, probably found picture on the net.
I have a 3000 lift handle but it doesn't have the hub, just the flat friction area like in the parts drawing posted. What's with the hub, my 71 3000 has the flat version, is this from an earlier tractor?
/ Ford 3000 draft control arm #13
We need to see what he has, not a stock pic.
That is a picture of what I need. I bent/broke the handle while backing up on a downed tree. A limb came in from under the seat, and I didnt see it. I bent the arm and the hieght guage. When I tried to bend these back into place the arm broke and the guage, well I just let it be. Its still bent and could use another also. I have searched all websites, and I find that I dont know the real name of this piece. The book calls it a touch control arm, but I have seen other names for it. I have been using a vice wrench to raise and lower while looking for the part, but again, I cannot find it. The parts houses listed above will not let me "drill down" to the part. I guess I need to find a local guy who has one he is parting out, but I dont see many of those around here. Please let me know if anyone has a lead on this! Thanks!
/ Ford 3000 draft control arm #15
no picture came through.
(INOP) 2020 JOHN DEERE 333G SKID STEER (A65054)
(INOP) 2020 JOHN...
2005 FREIGHTLINER FLAT TOP DAY CAB ROAD TRACTOR (A65054)
2005 FREIGHTLINER...
Unused Hustler DG LM200 SS 79in Hydraulic Dual Cylinder Grapple Loader Tractor Attachment (A66734)
Unused Hustler DG...
RIDGID AIR COMPRESSOR (A68842)
RIDGID AIR...
2010 BRENNER TANK PUP TRAILER (A67714)
2010 BRENNER TANK...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2018 FREIGHTLINER...
