Ford 3000 3pt issues
   / Ford 3000 3pt issues #11
Most of the time the kind of screen I'm taking about goes into the sump, but can be removed from outside of sump. Check your manual real close.
Hmm OK didn't know anything about that I'll look into v when my manual gets here
Just so I'm clear the sump is the hyd resevoir right? Because I have 2 filters. One is the intake and goes to pump the other is the pressure that comes back into the hydr resevoir. This sump is something different?
I forgot to mention, after doing some thinking. I don't know the name of it but it is our was connected to my top link. I broke the part where it hooks to the top link. Is that the unloader valve?
Doing a little research I think I might have broken the top link yoke when I backed up into a tree stump. Not real sure if that would be causing all this but it broke pieces off of it. Where can you get parts for that at?
   / Ford 3000 3pt issues #16
this post is perplexing.. if you are going to talk in pronouns and dohickies and thingy's.. we will need pictures.
your filters are under the top cover. no side slide out tubes like leejohn is talking about on some other tractors.
just for the heck of it.. you don't have a screw on can style filter at the pump or under the running board do you?
now post pics of the dohickies that you think are broken before we get too far down one path that might not be correct.
as far as air leaks? suction side air leaks cause the most problems..
Yea I'm sorry about all that. My manual should've been here by now. So far I've ordered a pump rebuild kit, top cover repair kit, cross shaft seals and felt seals. Part # C5NNNB53B is bent up pretty bad and leaking. Part # C5NNN949A is blown but can't find parts for either of those. I also ordered a new hydraulic elbow going into sump as it was leaking too. Looking closer at the flow control linkage, the c clip and washer were missing where it attaches to the valve and the valve was stuck in the closed position. I'll upload that picture real quick too.
That is what backed up into a stump, had a box blade attached to it.
   / Ford 3000 3pt issues #19
ouch.. with everything wrong you listed.. I might be looking for a 3000 rear end and swap over all the hyds from it. :)
Well I hope not, surely I can find the parts somewhere. Hope your joking.
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
ECHO SRM-2210 GAS POWERED WEED EATER (A51244)
ECHO SRM-2210 GAS...
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Genie GTH-644 (A50490)
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
